# Celonis Academy Courses
In [Celonis Academy](https://academy.celonis.com/) you can find numerous valuable learning resources.
For example, here is a webinar on how to use the Knowledge Model API:
- [Integrate using the Knowledge Model API](https://academy.celonis.com/courses/integrate-using-intelligence-api)
  - Access and display intelligence from Celonis to third-party apps!
[](https://academy.celonis.com/)
