Project process analysis document template
The project repository object has recently been extended to store analysis attributes (e.g. fom an kai zen project or an ISO project), as it can be seen in the image:
screen
The document template for project process analysis has been designed to integrate all these extensions into a generated document.
The document template for project process analysis can be called via any project repository object, as it can be seen in the image:
screen
The resulting documents contains a chapter, that includes the project process analysis data, like:
screen
