Skip to content
Last updated
Exploring the schema endpoints
This can be considered Part II of the Getting Started page. If you haven't read it yet, we strongly recommend you to do it before proceeding.
In this tutorial we will guide you through the different schema endpoints available in the Knowledge Model API.
List of Knowledge Models
As we saw in the Getting Started page, you can get the full list of Knowledge Models that you have access to, creating a request to https://<team>.<cluster>.celonis.cloud/intelligence/api/knowledge-models (remember that you need to replace <team> and <cluster> with your own values).
Knowledge Models response
List of Knowledge Model Filters
You can get the full list of filters that a Knowledge Model has, creating a request to https://<team>.<cluster>.celonis.cloud/intelligence/api/knowledge-models/<km_id>/filters. For this URL, you will need to replace the <km_id> with the Knowledge Model id that you got from the previous endpoint.
Knowledge Models filters
List of Knowledge Model KPIs
Similar to filters, you can also get the KPIs for a given Knowledge Model. To do this, simply append /<km_id>/kpis to the URL you used to get the full list of Knowledge Models, i.e. https://<team>.<cluster>.celonis.cloud/intelligence/api/knowledge-models/<km_id>/KPIs.
Knowledge Models KPIs
List of Knowledge Model Records
Similar to filters, you can also get the records for a given Knowledge Model. To do this, simply append /<km_id>/records to the URL we used to get the full list of Knowledge Models, i.e. https://<team>.<cluster>.celonis.cloud/intelligence/api/knowledge-models/<km_id>/records.
Knowledge Models records
List of Record fields
Finally, you can get a list of all the fields that can be consumed for a record, by appending the id of the record that you got in the previous endpoint, i.e. https://<team>.<cluster>.celonis.cloud/intelligence/api/knowledge-models/<km_id>/records/<record_id>. This list contains Attributes, Augmented Attributes and Flags.
Knowledge Models fields
In the next tutorial we will look into how to consume the data for a record.
